Looking for specifications for table hole thread sizes, pitch, and separation.
The folks at support@carbide3d.com should have that.
This is what you need:
Nomad 4 Table.pdf (229.2 KB)
M6 threaded holes are on a 25x25mm spacing.
5mm dowel pins (recommend using undersized dowel pins) are every 50mm, between the holes.
