Nomad 883 limit switches
(Gary Davis) #1
I have an 883 Pro that has been mothballed for a while, and am trying to get it working again. However, trying to start the homing process, it tells me a limit switch is hit. I’ve turned it off and moved things so none of the 3 are engaged, and they all seem to click in and out ok. Am I right in guessing the next step is to take off the back and check connections to the main board?
Thanks,
Gary
(William Adams) #2
Yes.
Remove the back, the press each switch in turn and make sure that it lights up the light on the controller when closed, and allows the light to go off when released.
If you can’t resolve this, let us know at support@carbide3d.com and we’ll do our best to help.
