Hey,
I’m selling a Nomad 883 Pro. Barely used for 5-7 hours.
Great accuracy but it ends up that I’m not patient enough to deal with it.
There are TONS of accessories that comes with it. I’m selling it ALL together, not selling the machine alone, however I can sell accessories individually if I’m requested.
Accessories:
4x DLC coated endmills cost 50€ a piece.
5+ generic Chinese endmill for wood and aluminum
2 collets for 6mm and 4mm with 5 microns accuracy (retail is 40€ for both)
2 SEALED collets for 6mm and 4mm with 5 microns accuracy (retail is 120€ for both)
2 collets for 1/4" and 1/8" those one are from Carbide 3D
Special Harvey tool endmill (Single tooth threadmill, round corner endmill…) (retail is about 200€ as I remind)
Flip Jig
Clamp Vise
Threaded Table
Stock wasteboard (used a bit but you can surface it)
Nomad stock tools
Stock replacement aluminum plate
Aquarium Pump (Retail is 100€)
There are a hole of 13cm diameter on the left side of the enclosure as I was planning to add it an HEPA filter with a fan, but I didn’t do it, so there’s just a hole.
I added a MQL system for throwing small amounts of lubrication for milling aluminum. The small brown thing you see is a regulator used for regulating flowrate of perfusion.
The pump that comes with it is strong enough to push swarfs around without making a tempest and causing the swarfs to go into the rods and electronics.
I might have forgotten to mention some stuffs.
Importing the machine ALONE with no accessories into the EU is 3000€.
I’m asking 3300€ for it all. Does not include shipping fees.
For questions don’t hesitate to send a PM.
