So, trying to do some PCB’s with RF componenets and need an “Area Rubout” feature to remove larger amounts of copper from certain areas. Carbide Copper supports this feature but sadly the tools library is too limited and I dont have any endmills which correspond to the fixed list.
I just played around with pcb-gcode but it does not support “Area Rubout”. Surfed the web for a while but short of complicated processes I found nothing easy. I did stumble on cirQWizard which looked really good but it does not generate gCode and requires direct connection to a CNC Router which uses their version of gCode.
I was wondering if anyone else had some other suggestions for a half way decent and reliable workflow ?
Thanks
