Nomad Highest Feedrate?
I am planning to use some Harvey Tools 1/4 one flute plastic cutters on my Nomad Pro to cut soft plastics/foam. According to the chart provided by the company, IPT can be 0.0098 with a DOC of 0.25 for my use. I put that in my software which tells me it will cut at a feedrate of 89 in/min @10000rpm. Can the Nomad cut that fast, considering the speed/torque of the positioning stepper motors and the spindle? If not, should I lower the feedrate or rpm?
Thank you for your help.
Jim
80 in/min seems to be the limit I’ve seen.
Thanks! I will try something like that.
Remember also, top speed will be limited by the possible acceleration over the longest possible travel distance.
