Nomad maintenance
I’m now using my nomad pro on a daily basis between 2 and 4 hours to get my ship frames complete.
There are a few high pitch noises coming frame the y movement, does the nomad need oiling? I am jus wondering what maintenance I should be carrying out?
It doesn’t effect it’s operation still working great.
Thanks Tim
P.s. once all frames are cut out I will update my previous post about the ship build
We have a page on this here: http://docs.carbide3d.com/article/13-what-oil-should-i-use-to-lubricate-the-linear-bearings
If it’s actually gotten to the point of making noise, I would worry that you would need to clean with a solvent first — but I don’t know the specifics of the materials involved, so can’t suggest a chemically compatible one — probably it’ll just be okay if you follow the above directions, and use a lint-free clean cloth to start, and repeat the lubrication and wiping process until the cloth remains reasonably clean.
Great thank you I will have a read :blush:
