To surface my Nomad wasteboard I’m planning on using a 1 inch Spoil board Surfacing Router Bit (3 flute). The bit has a deeper section in the middle which will affect the proper height measurement by
the bit setter. While doing a search on the forum, someone suggested disabling the bit setter but also mentioned that the Nomad can crash doing that.
What is the best way to use a Spoilboard Surfacing Router Bit on the Nomad? Do I need to disable the bitsetter?
