Noob here. 1st wasteboard attempt tonight, didn't turn out great. Advice?
Glad to be of some help. One other thing that I accidentally found is that when moving the rail by hand it is possible to get out of square. After you’ve finished sorting out the belt tension, it would not be a bad thing to check the gantry squareness vs the side rails. Will try to edit this post in a little bit with the link to that post.
For your enjoyment
