I am cutting an 8" trivet that is 2 sided with opposing diagonal slots. The piece is 3/4" thick, and 8"x8". I am using the Shapeoko Touch Probe to zero the X, Y & Z axis at the lower left corner using the Probe function in Carbide Motion.
The slots are 3/8" deep on both sides and I am insuring that the thickness id “exactly” 3/4". What is happening is that the cutter is not going the full depth of 3/8". The actual full depth is something less, like short about a 1/32" or so on each side.
My spoil board has been surfaced so it’s definitively flat. In the project I have the start depth set to 0.0" and the depth of cut set to 3/8", which is half the thickness of the piece.
How are you doing this? If you use “3/4” in the software, but the real material thickness is thicker, then you will leave a band of material uncut in the center of the material.
It is very important that your toolpath matches the exact real world thickness of the material.
If the CAD and CAM geometry checks out, then it’s something physical:
wasteboard trammed to be parallel to X and Y axis motion?
stock actual thickness? When I did a similar cutting board I used rough cut lumber, so faced/planed off one side, then flipped and registered off the surface of the wasteboard
Have your checked your calibration. The belts can stretch and cause slight deviation to the depth cut. Are they cuts all the same depth, if not, you may be getting some slippage of the belt on the gear or on the shaft.
