Not listing tool # when running job / Bit change?
I’ve searched and can’t seem to find any answers. I’m sure it’s something I screwed up, but can’t for the life of me figure it out.
2 questions in one
In the older version, when it was time for a bit change, it would list the # of the bit to install.
I have the latest build and now it just says bit change - what step did I miss?
When it came time to change the bit, it used to come the front center, with the new version it just stopped where it was when it said bit change.
I know I’m missing something there too.
Thanks for any help.
Paul
I have not quite followed subtle workflow changes between the last versions of CM, but about that second problem, I remember someone recently had a problem where the machine would not move to the front center for bit changes, and it turned out to be because he had an XXL and had unintentionally changed the machine to “Standard” in the settings (“XL” would do the same).
Do you have the BitSetter enabled?
I checked before I left for work this morning and I verified that I have XXL selected in settings
I verified that I do have it enabled, the machine goes to the bit setter when I initialize it, and when I start the job after zero.
