Not sure i am doing this right
I have been trying to design this pivot hinge for my enclosure lid. The trim vectors has me a little baffled.
I created multiple circles and trimmed what i didn’t want. This is the correct shape but not sure i made it correctly or if there is an easier method. I think there are stray nodes in there too.
Lid-ARC-pivot.c2d (52 KB)
I would like to know how it should be done.
Thanks!
The file seems fine:
but it is made up of open vectors (indicated by being magenta) — you probably want closed so select everything:
and use the Join Vectors command
Yes
However, there seems to be something odd in the geometry:
If we draw in a crossing bit of geometry:
Select both:
and use Trim Vectors to remove the excess:
and if need be use Node Editing:
d
to finish cleaning up
d
zoom out, re-select and go back into Node Edit mode:
Select the two nodes which were nudged out of the way:
and restore them to their original position by nudging them back:
Done
Attached as a v8 file.
Lid-ARC-pivot_v8.c2d (52 KB)
WOW, Thanks Will! I am learning a ton on this forum!
Geometric constructions can be difficult when overlapping/intersecting/coincident lines interact and sometimes things get confused.
Examining things patiently will usually reveal a way to solve it, and the new feature “nudging” a node selection with the arrow keys allows one a great deal of facility in examining the underlying construction.
I wrote up a bit on Carbide Create at:
which may help — if anything in it is unclear or needs updating/correcting, let me know and we will look into it with you.
