I was in CM 566 last night and I was starting a job, changed the bit and it went over and hit the bit setter, then came back to turn on the spindle. I realize, I don’t think I changed the starting zero. So I hit the X to close the window, except it just pretends I hit OK and takes off. Then I thought well I will hit stop and it would not stop - the big red button finally stopped it. I would think if anone hit the X in those pop ups, it wold mean hang on, maybe I am not ready?
Number two isn’t a bug per se, but with the new work flow I feel like it woud be nice to “unload” a file. so I could edit it in CC then load it back in CM - right now, I have to shut down the entire program and re-initialize everything or change the file name - which is what I do, but it sure makes a mess of my file system. Just a thought
Have had this problem as well running 566. Usually it’s before it wants to go to the bitsetter and I realize I have the wrong bit and hit X on the bit change dialog box. Still goes to do the thing.
And after stopping it in this method, the z axis then starts descending very slowly and it eventually throws an error, and the machine needs to be re-initialized. I forget what the error is, but it’s replicatable.
In previous versions hitting the X at a bit change prompt would pause, so pretty sure this is a bug.
