Notes saved In CC
Entering Notes into Carbide Create.
I know you can enter notes into a file that you create under the DESIGN tab, however you can’t access those notes unless you are in the file you created the project you made.
Does anyone know if there are plans to allow notes to be accesses when in any file you create. It would be nice to make notes on about bits that you use and changes you make to speeds about feeds and materials.
Thanks jd
Are you looking for a “global notes” that’s available in any file?
