You’d think I’d have made it out to the garage by now to take a picture! Alas I have not, but this is a good representation of the 1/4 → 1/8 reducer I bought from C3D in ~Apr 2019 with my SO3.
Sure. Of course I can’t find it, but ~1-2yrs ago I asked if these were compatible with the Makita that I have. Support said “Yes,” and I suggested adding that to the page. Still don’t see this called out, and I don’t trust my memory, so I have to ask again: are they compatible?
And can someone put that on the page to prevent redundant asking?
I run an XXL with the standard router and had the same exact problem. On my final pass to cut out the project, the router made a hard right turn, dug in and destroyed the piece. When I removed the bit, collet nut and pried out the collet, I observed that the collet compression grooves and nut were packed with sawdust, enough so that it impeded fully tightening the nut. My standard procedure now is to fully remove the nut and collet between bit changes, turn the nut over and tap on table to remove the dust and inspect/clean the collet grooves. I was surprised to find how much sawdust actually collected in the collet. I’ve not had a reoccurrence of this issue in over 100 hours routing over the holidays.
