Just updated to both the most recent versions of CC and CM for mac; I have all the min requirements met.
Love the new interface, but now when I load my older .c2d files, it crashes CM when I click “Send file to Carbide Motion”.
Fine.
I decided to rebuild the toolpaths, that seemed to solve the crash issue. But now when I send the files, even tried a brand new file with a simple circle within a square, one tool, one toolpath, V-bit 60 deg… everything default, nuthin fancy, it sends/loads the file fine into CM, but then in the new preview mode it shows like 10-50% of the entire job and then just abruptly ends. And it always says “Under 2 minutes” for the cut time. Which it definitely is. It’s more like 1 or 2 seconds of cut time.
I thought maybe it was just the preview, ran a job and the spindle just stopped after one path basically and froze there spinning in place, no error or anything, it just stopped and acted as if it had finished the job, but it didn’t retract the Z back up.
