Until I embark on a K-factor & temperature measurement adventure (now delayed because I need a new dust shoe, and that requires my 3D printer to behave…), I figured I would take some time to look into another topic, which is required chiploads/feeds and speeds for V-bits and Ballnose endmills.
Try as I might, after hours of reading from tons of different sources, I could not find any useful background/theoretical info for selecting F&S specifically for V-bits. Common answers I have seen are:
that since depth of cut and therefore effective cutting diameter varies constantly during V-Carving, it is pointless to aim for a given chipload (I don’t get that one, since chipload is independent of endmill diameter…)
that feedrates need to be conservative because that pointy end is weak (which makes no sense to me either)
that RPM need to be as high as possible, because at the tip the SFM is really small, close to zero actually. This one I buy.
but mostly that one should “try and see what works”. Very down to earth, but not what I am looking for.
BW has a page about how V-bits are different and F&S need to be compensated accordingly, but of course zero details on the nature of these adjustements in GWizard…
So, do you guys have recipes you use to select feeds & speeds for V carving?
Similarly for ballnose endmills, I have not found anything interesting. I presume mostly because in 99% of cases ballnose are used for finishing 3D jobs and the stock to leave is so small that pretty much any feeds and speed could work?
I usually compensate with varying router speed as the cut deepens.
In my experience V bits are extremely durable but I also use good bands, Kyocera and Destiny. The flat on the end on mine are around 0.010 and they have cut pretty much everything without chipping out or any issues. On feedrate, really depends on the material but the end of the cuts with v carving will usually be around full engagement and it can have a tendency to chatter if you don’t keep an eye (metals). Lubrication is important in metals, especially the first few passes, helps with the tip sfm issues. Keep in mind you can also use v bits for adaptive cutting, I like a 0.009 opt for two flutes (has to be less that tip flat diameter)
Lots of good calcs there, thinning based on type of cut and surface quality. Imo ballnose cut quality is mostly on how you leave your finishing stock. Its still a good idea to cam out based on chipload but keep in mind you can push much harder because you aren’t removing that much.
One tip is for finishing it to run square approaches as it can have a certain visual effect. Stepover equal to chipload, minimum 0.001/0.001 and I usually max around 0.005/0.005 depending on desired surface or time limit.
Also when using fusion it can be a good habit of duplicating your adaptive roughing and running it with a ball and rest machining to the previous op. This will get 3d surfaces much closer to final shape and minimize load spikes of going directly from square rough to ball finish.
edit deleted stuff about sfm. Doesn’t really matter here.
IMO it’s probably wise to go with the endmill manufacturer’s recommendations (unless they used GWizard to develop them ). As shown below, it probably makes sense to use the same speeds and feeds for both ball and flat nose endmills. KISS
Note that the chip loads are proportional (K) to endmill diameter (as you previously pointed out) for a given SFM. That keeps cutting edge impact forces the same for all diameters because they’re inversely proportional (1/K) to RPM, which itself is inversely proportional (/K) to diameter. Hope that’s confusing enough!
That, in conjunction with the “for better surface finish, reduce feed per tooth” note, suggests that the endmill manufacturer chipload recommendations are maximum rather than minimum values.
It would be interesting to see how those SFM recommendations correlate with material harnesses and K factors. (Kennametal has calculators too).
Their user guide has a different definition of HSM than most(?) - “High Speed Machining defined by very shallow radial width of cut and increased table feed, due to radial chip thinning effect.”
BW mentioned this diversity of HSM definition/origins in this article. Re-reading that, and especially the part about “various shops discovered HSM techniques can work well even on slower spindles”, makes me think the core of HSM is more generally to take lighter (low engagement) but faster (as in feedrate) passes.
Or maybe the word HSM just got so trendy that everyone started using it just to be part of the gang
Definitely agree. Both because of what you say, and because I guess it would be dangerous for them to advertise a single value that is a minimal chipload, and could be erroneously compared to the max value from another manufacturer. Which is why I was (pleasantly) surprised when Vince pointed out that Lakeshore provided minimums too.
F&S for ballnose can be the same or even more aggressive than for square endmills since:
at least Kennametal recommands identical chiploads for this ballnose endmill example vs its square sibling.
ballnose usually comes after an initial roughing pass, so has less material to remove.
ballnose can take at least the forces that a square endmill can and probably much more, since it does not have the sharp corner angle, so is less susceptible to chipping.
for V-bits…still unclear to me. @Vince.Fab, I hear the general (and very useful) tips you provided, but it does not give me a recipe for predetermining a proper starting point for F&S for a given situation. What I think I’ll do is check what CC, VCarve, or various guides out there recommend for a few typical situations (say, 60° and 90° V, in hard wood and in soft wood), and see if a pattern emerges.
I want to use a profile (router) bit for a project and I’m scratching my head on the best F&S to use as the set I have (like most I suspect) came with no specs. As many have experienced burning wood when using them manually, it can be tricky to find the sweet spot between a good cut and burning and chips and most of us will rely on the sound to make adjustments. From what I have seen, recommendations are for maximum or range of RPM for a given bit but no F&S like in this article from Rockler. In the case of a CNC, it could lead to a quick crash if FR is too ambitious for the bit used.
I’m sure many have used them in their CNC but I have not seen information posted. Does anyone have recommendations based on experience for common bit types e.g.: roundover or cove bits?
In the process of trying to find one, I came across a document from Shopbot that provided target chipload for V bits and ball endmills that may be of interest to @julien but not for profile bits
Well, after a bit of more digging, I found that some but not all profile bits in the CNC section of Freud Tools have a good calculator on the page for the individual bits that provided the Feed rate range at a given RPM. It looks like many of the 1/4 shank bits do not have that calculator function unfortunately.
for cove bit, maybe this set of F&S could be of interest ? (I have no experience with cove router bits, but this amana “core box” looks similar)
EDIT: so it looks to me like you could just apply the “usual” chipload guidelines (maybe the low end of the range), and compute F&S as you would for and endmill
Yep, especially due to the lack of a corner tip on a common square end mill.
That is the area most prone to damage that can escalate as soon is it wears/chips.
This is the reasoning behind bullnose endmills or corner radius endmills. Their ability to be pushed as a rougher (lack of weak tip), yet have a decent stepover (b/c mostly flat) so you have good MRR. You can push a ball end mill as well, but you have to deal with the cusp of stepover on the floor surface.
Maybe they, like Kennametal, are providing a (much broader) range of maximums to account for variations in hardness in their broader material groups and/or SFMs?
In addition, in a slotting operation, there is a significant difference in the amount of surface engaging the material compared to a square endmill. Maybe the rounded shape could also make it easier, than a square endmill, to pass through areas where chips are not completely cleared away.
For speeds and feeds on v carving I just used CC recommendations and scaled that, I think they use 0.0015 if I remember correctly.
If deep V carving standard chiploads seem to work fine but when lightly engraving (<0.030) i usually cam it like it’s a 0.010 endmill, due to the end flat. I’ve only v carved metal though so wood might have a much larger sweet spot.
On bull endmills - they take a significant amount more force to cut if used like a square endmill and it goes up the larger the radius. Example, there’s a significant speed difference in roughing with a 0.020 rad vs 0.060…however the ability to make a smooth 3d finish without toolchange might be worth it.
Doesn’t the lower table include profile bits? Not that the article and tables provide much useful guidance (especially since they are only for 18000 RPM). Also, note the “this chart is a recommended starting point and does not warranty against tool breakage” caveat and the “always check to ensure the rated speed of the router bit is higher than or equal to the maximum speed marked on the CNC machine” (which aren’t readily available) warning.
Their calculator seems to suggest that their endmills are ok for 49000 RPM, but the original caveats still probably apply. So, “buyer beware”!
Freud’s calculator apparently determines what should(?) be achievable with their endmills. A different type of calculator is necessary to estimate what should be achievable on a CNC machine. The calculator discussed here can do that. Even though that calculator assumes standard straight endmills, it should be usable for other geometries by calculating (or estimating) an equivalent cutter cross-sectional area at the required DOC.
Just real world seat of the pants observation. There are multiple parts i make that I wouldn’t mind to rough and finish with the same bull endmill but speeds and feeds have to be dialed down too much.
Freud used to claim that their router bits < 1" diameter are “so well balanced that they can be used at speeds well in excess of 24,000 RPM”. So, IMO you should be fine if you stick with Rockler’s RPM table (which is similar to Amana’s) for woodworking router bits. Wouldn’t you do that in your router table and feed as slowly as necessary (maybe even “making dust not chips”)?
The chip-loads provided in Freud’s tables are about 10 times higher (hence capable of 10 times the force) than what you’d want to use on either your router table or your CNC machine. I roughly guesstimated the cross sectional area as 0.375" X 0.375" for that bit milling MDF at 24000 RPM and 59 IPM in the following example. Note that because the chip-load was reduced to ~0.001", a reasonable cutting force of 3.3 lbs should be possible.
No, but if anyone does I would be quite interested to hear about the added value. I might even shell out 49$ for one year to see what it is all about. After all I bought GWizard and now use it so seldom that it complains about needing to “connect to the Internet soon” every time I do launch it.
