A pocket tool path is calculating perpetually and seems to be frozen. I’m not able to delete it. Any ideas on the cause or solution?
Are you using the current version?
Try the beta?
If you can create specific instructions for causing this hangup, upload the file here and we will look into it.
Yes using the latest software version. I added a tool path to an existing project that was to replace the existing tool path but did not delete the original tool path so l’m thinking there’s a conflict that has hung it up.
Never mind I figured it out on my own.
Please let us know what the problem was and how you solved it.
Share the fun.
Thanks
I don’t know what caused the problem. All I did to resolve it was to exit CC and open it back up.
Early versions of CC v7 had similar problems. Then it was random but seemed to happen more on very complex files with lots of vectors. As CC v7 progressed that happened less and less.
I still have CC hang in Toolpaths. Seems like it happens about two steps behind my noticing it. I suspect that I get in a hurry and tell it to do something before it finishes calculating.
