Resolved: Pinouts for BitRunner
So, in an effort to not void the warranty on my BitRunner, I think I may go down the lines of @Madboy’s post, here.
Is it simply the case of connecting pin 6 to the ground connection and pin 3 to the tip of the stereo plug, then enabling BitRunner and saving the settings to the Shapeoko?
It just seems a bit too simple!
Thanks
It does seem simple, and pretty much is.
Pin 3 has 0v when the spindle isn’t running, and a pulse of voltage when it is running which approximates a non-zero voltage.
If the device is really really fast, it might switch the router on and off hundreds of times a second… but more likely, there’s a capacitor in there somewhere that smooths this out so it will just turn things on. Probably.
There is a setting in Carbide Motion that says you have spindle control hardware. Not sure if you need to enable that, but I did when I connected a VFD to those same pins.
As far as I know, that setting only prevents CM to show the pop-up window telling you to turn on (or off) your router. For sure the controller board generates the PWM signal unconditionally whenever it sees a M3 command in the G-code, since this is a GRBL behavior.
@NewToThis I’m not sure I understood what you want to achieve, if you already own a BitRunner? (and I suppose your mention to “BitSetter” was a typo?)
I missed that - you stole a chance for me to be pedantic. Curse you :smiley:
On a more serious note (sort of), perhaps C3D should retire the BitXXXX nomenclature. It is often a source of confusion on the forum.
You, @Julien, could run a monthly competition for new names. In that spirit, and since it’s obviously going to happen, here are my suggestions:
BitZero: C3D WhereAmI?™
BitRunner: C3D SpindleStarter™
BitSetter: C3D HowLong?™
(edit: I did consider BitSetter=> C3D HowLongIsMyTool?™ but decided to keep it safe and serious)
Argghhh! I keep doing that!
Note to self: Read it again - and then again - before clicking “Submit”.
I have a bit of an issue with the connectivity of the BitRunner, in that I’m UK-based so the connectors require adapters, which I’m not fond of using, and the router lead is really short, making it difficult to change the outlet to a UK version (the cabling is also really thick) without soldering in a new cable, ultimately affecting the warranty.
I was rather hoping to use this, as a suitable alternative instead.
I didn’t have you as one lacking in courage :rofl: :rofl:
Peter
It really is that simple and the Keane device must have a debounce circuit which aggregates the incoming PWM into a simple on / off.
My experience with it has been that you can use M3 S1 upwards to switch on reliably.
I then use the IEC standard output to a twin UK 13amp socket (in orange to show it’s switched) to power the spindle and vacuum cleaner.
A UK Naval competition to name the newest research vessel in the fleet received the most popular vote by far: “Boaty Mc Boat-Face”. The Navy rejected this, but did use it for the submersible associated with this boat.
So… Bitty Mc Bit-Face, Spinny Mc Spin-Face, and Proby Mc Probe-Face?
