My shapeoko 5 is having a problem. I set my X,Y,Z and machine homes correctly but when it cuts is goes about 1/4" setting is at 0.060 per pass.
What am i doing wrong?
Without more info it’s hard to diagnose?
The Z height goes about 1/4”? Into the material? In the air?
Can you post the file so it can be reviewed? Or photos of the issue on the piece of stock?
Usually it is caused by a mismatch between job setup:
https://carbide3d.com/hub/courses/create/job-setup/
and how origin is set relative to the stock:
https://carbide3d.com/hub/courses/running-shapeoko/movements-zeroing/
