Occasionally, I have had issues where I have had a bit slip in the collet and pull itself into the work. (I have that happen a lot less now that I have more experience) but I had it happen the other day on a long carve building structural pieces from 2x lumber for a filter box for my AC.
Since I had a suspicion that there might have been an issue, it occurred to me with the pause functionality it might be possible to have a verify tool length option.
How this would work would be
- If you were suspicious of tool slippage or lost z steps, hit pause
- in pause mode, there would be two options: resume (a bigger button would be nice) OR verify tool length
- If verify tool length is chosen, the tool length would be remeasured
3a. if the length was correct the Resume button would appear (maybe a message so tool length verified)
3b if the length was incorrect a warning would be sent, something like āWARNING: Tool slippage or lost stepsā - The recovery process would have to be thought out. If it was just slippage in collet, there could be a remount, remeasure, continue sequence. If it is lost steps, I am not sure on the recovery process.
I was thinking slippage in collet would be longer, but that may only be for upcut bits. Iām guessing lost steps would be usually shorter (collet nut hitting an adjacent feature etc). Might be enough just to know things are off, and the individual has to workout the recovery.
Just a thought.
John
