Trying to run a simple 2D Engrave Toolpath with the 30deg Amana V Cutter
Getting the following error in the .nc file that is generated:
(1004)
(T45771 D=0.25 CR=0 TAPER=15deg - ZMIN=-0.042 - chamfer mill)
G90
G17
G20
G28 G91 Z0
G90(Engrave3)
T45771 M6
S18000 M3
G54
G28 G91 Z0
G90
G28 G91 X0 Y0
G90
M30
!Error: Failed to post data. See log for details.
Here’s what the log says:
Information: Configuration: Carbide 3D (Grbl)
Information: Vendor: Carbide 3D
Information: Posting intermediate data to ‘/Users/MarkDGaal/Desktop/1004.nc’
Information: Total number of warnings: 2
Error: Failed to post process. See below for details.
Start time: Sat Feb 1 22:30:53 2020
Loading locale from ‘/Users/MarkDGaal/Library/Application Support/Autodesk/webdeploy/production/742b51de82fb690ad30c10d35d2e983ab4a4fc6a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts/common.en.lang’
Post processor engine: 4.55.0 0
Configuration path: /Users/MarkDGaal/Library/Application Support/Autodesk/webdeploy/production/742b51de82fb690ad30c10d35d2e983ab4a4fc6a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts/carbide3d.cps
Include paths: /Users/MarkDGaal/Library/Application Support/Autodesk/webdeploy/production/742b51de82fb690ad30c10d35d2e983ab4a4fc6a/Autodesk Fusion 360.app/Contents/Libraries/Applications/CAM360/Data/Posts
Configuration modification date: Fri Nov 1 20:41:16 2019
Output path: /Users/MarkDGaal/Desktop/1004.nc
Checksum of intermediate NC data: fccdb46bd7bdbd6783cdcb40700a6753
Checksum of configuration: 51e50f55a0d8ef3b14b6321e9666f9c0
Vendor url: http://www.carbide3d.com
Legal: Copyright (C) 2012-2018 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.7421
Warning: Tool number exceeds maximum value.
Warning: Work offset has not been specified. Using G54 as WCS.###############################################################################
Error: Length offset out of range.
Error at line: 374
Error in operation: ‘Engrave3’
Failed while processing onSection() for record 278.
###############################################################################Error: Failed to invoke function ‘onSection’.
Error: Failed to invoke ‘onSection’ in the post configuration.
Error: Failed to execute configuration.
Stop time: Sat Feb 1 22:30:53 2020
Post processing failed.
Tool settings are imported from Amanda’s .tools file.
