Potential Defect: Add node to poly line or curve
Unable to add a node to a single curve or poly line.
Steps:
Create curve or poly line with only beginning and end nodes.
Complete line creation
Select new line
Select Node Edit tool
Right-click a point on the new line
Select Add Node from the popup menu
Result: No New Node
CC: Build 815, Built on: 2025-03-19
MacOS 15.6.1 (24G90)
MBP M1 2020 13"
Please upload the file and a screen grab showing where you are trying to add the node and we will add it to the list of test files.
Here you go.
Thanks @WillAdams
CC_NoNodeForYou.c2d (44 KB)
I cannot reproduce this on 821.
Node Created:
Win 10.
It’s safe to say that anything related to node editing should be tested with the beta. There are thousands of lines of code that have been changed to make it more correct.
Hopefully, we’ll have another new build coming tomorrow.
