Power cord length
I have a HDM v3 and would like a little longer power cord.
It is my understanding that the control box uses a IEC C13/C14 AC female plug and the plug that connects to power uses a NEMA L6-20P. Can i safely use a 15’ cord of this type?
Amazon has several to choose from in this length.
Alternatively i could just by a longer IEC C13/C14 AC cord and put the NEMA L6-20P twist lock on it.
Thanks, Joe
Extension cords work but a direct connection is better. I moved into a new house in Kingwood TX. I installed a 20 amp 220 plug for my tablesaw. Worked fine but I did not buy a twist lock plug and socket. The plug backed out and only had 120vac and burned up my Powermatic 66 motor just before Christmas. It cost me $600.00 to replace the motor. So if you can put a twist lock plug in to keep your connected all the time. Personally I would buy a longer cord instead of an extension cord.
Thank you, yes considering a new cord.
The IEC C13 plug is limited to 16A so, you should use at least a 14ga power cable.
If you are comfortable with it, buying an extension cord and replacing one end with the IEC C13 connector may cost less depending on how long you want the cord to be.
If you end up going more than 25 feet, I’d step up to 12ga wire. But I tend to over design things.
Thank you.
I could probably reach the outlet with a 10’ cord. I used to have a Lathe plugged in there.
Second this. It’s an easy process:
