I am about to start on some relief carvings in brass with a v bit. Just a 40mm coin blank.
I got to thinking though. These tips are rather fragile and brass isn’t exactly forgiving… plunging the tip seems like a bad idea.
Do you folks think predrilling a predefined location will help with the tip life? I assume dropping into the hole before moving laterally to start the cut will help.
Is it worth the hassle/tool change? Or do you think a shallow ramp entry would suffice and save a tool change?
