So today, I am attempting to set up the bitrunner with the carbide compact router on the pro 5 and cannot seem to get it to work.
The manual is not updated for the 5 pro but it looks like you use the extra spindle wire connector you get with the 5 to connect to the bit runner cable to the controller spot for the spindle. That is the only way I see to connect the bitrunner to the controller, but honestly not sure if it’s correct.
So far, I cannot get the router to turn on using the bitrunner but I am guessing I am missing something, and it’s user error?
Did anyone get this working that can give me some tips?
Thanks!
