What size are the balls in the Y-Axis bearings. My Calipers say 2.77mm to 2.75mm. Also where can I buy 50 of them to rebuild my Y-axis linear bearings. Just the four Y-Axis need to be rebuilt. Moved and wasn’t thinking and took the gantry off so I have few missing. balls went everywhere. If I’m going to rebuild them I want to use the best available. I found these on Amazon https://www.amazon.com/uxcell-3500pcs-Carbon-Bearing-Precision/dp/B098T157T1/ref=sr_1_5?crid=14DO5FZSRTUX1&keywords=2.8mm+ball+bearings&qid=1659593810&s=industrial&sprefix=2.8mm+ball+bearings+%2Cindustrial%2C152&sr=1-5. They have 2.5mm as well. 3500 is a lot of balls. Thanks for the help.
I don’t know the answer, but I would advise to contact support@carbide3d.com about this
