Probing Cycle Error Failed
Hello,
Newbie here. I’ve read through the past post on the Probing Cycle Error Failed message, but still have the problem. The probe seems to work fine in determining surface alone. However, when I try to probe a corner, it apparently gets stuck determing Y. Please see the below link for a video. Many thanks in advance.
https://drive.google.com/file/d/1UpR2yy7DNCaVS9aPePgWu36M987apzBt/view?usp=sharing
I would try again with the probe more centered in the hole. The cycle will time out if the machine travels beyond a certain distance, and from your video, it looks to be just short of touching the block.
That was the problem! Thanks!
