Probing in post processor
Does anyone know of a Fusion post processor which will allow in-op WCS probes and is compatible with Carbide Motion sender+board? I don’t really have the time to go down the rabbit hole of extending the Autodesk provided one.
I’d like to be able to face in op 2 and then access/probe a couple of edges which are then exposed from op 1.
One alternative is to break my ops up into separate files and then use macro in Carbide Motion; G38.2 seems to work in MDI.
I do have a BitZero but I can’t always get it into the place I want to probe and the the standard CM BZ zeroing routines obviously only locate the centre between two opposing faces (like a hole)
This topic was automatically closed after 10 days. New replies are no longer allowed.
