Hello all,
The problem I am having is that Carbide Motion does not prompt me to change the cutters. Instead, it continues to operate with the first cutter (which happens to be a 0.25" face mill).
My set up is as follows:
iMac 27-inch Mid 2011 / 8GM memory / 3.1GHz Intel Core i5
Fusion360 CAM
mach3mill.cps post processor
Carbide Motion version 2.0.314 (2015-04-09)
I have attached some illustrative images for reference.
Any help would be very much appreciated!
Thanks,
Nick
Carbide Motion paused after not prompting to change cutter:
Fusion360 CAM setup showing the different cutters assigned to each operation:
Nomad883 paused after beginning to cut the next operation without prompting to change the cutter:
This is a snippet of the G code:
(1001)
(T1 D=0.25 CR=0. - ZMIN=0. - FACE MILL)
G90 G94 G91.1 G40 G49 G17
G20
G28 G91 Z0.
G90
(FACE2)
M5
M9
T1 M6
S12000 M3
G54
M9
G0 X2.3292 Y-3.3036
G43 Z0.85 H1
Z0.45
G1 Z0.27 F20.
G18 G3 X2.3042 Z0.245 I-0.025 K0.
G1 X2.1667
X-2.1667
G17 G2 Y-3.0679 I0. J0.1178
G1 X2.1667
G3 Y-2.8322 I0. J0.1178
[continues the face milling operation]
G1 X2.1667
G18 G2 X2.1917 Z0.15 I0. K0.025
G0 Z0.85
G17
[right after the face milling operation is complete, it continues the next operation without prompting to change the tool—why?]
(RAMP1)
M9
G0 X-1.7123 Y-2.4435
Z0.525
Z0.2037
G1 Z0.1313 F20.
G19 G2 Y-2.4498 Z0.125 J-0.0063 K0.
G17 G3 X-1.706 Y-2.4561 I0.0063 J0.
G1 X-1.6681
X-1.6647 Y-2.4562
X-1.6407 Y-2.4569
[etc.]
