Problem cutting letter
(Bob zambron) #1
I’m trying to cut the calligraphy letter z. I’m using a v bit #302 as you can see from the pick it’s not cutting the black line area. So the letter when cut doesn’t look correct. I’m thinking I’m using the wrong bit to cut. If that’s correct then what bit would I use?
(William Adams) #2
The problem is the letter is sized too large for the 1/2" diameter endmill to cut it out.
Please see:
