If I create an SVG and try to pull it in to Carbide Create, nothing shows up. If I add it to Adobe Illustrator and resave, Carbide Create will pull it in. Is there something I can do so that I can create an SVG and not have to use Adobe?
Please post the problematic SVG here, or post it to projects@carbide3d.com
If opening it in Illustrator and re-saving fixes it, most likely the problem is that it was made in Silhouette Studio/is made up of “clone” objects — Inkscape will also fix such files.
Are you exporting (not saving) out of Illustrator?
Yes, I am using Silhouette to create the files. Thank you! I will “fix” in Inkscape.
I bring the file into Illustrator after creating in Silhouette, save, then import into Carbide Create.
