Hi,
I have problem with cutting circle in shepeoko xxl. could you please help me out?![
Hi @Amila,
It looks like your machine could use a mechanical check/tuning: make sure ALL you eccentrics nuts (on X, Y and Z axis) are nice and just tight against the rails, and the the setscrews on ALL four pulleys are tight and one setscrew ouf ot the two is aligned with the flat on the motor shaft.
And then tell us more about the settings you used for that project (bit, feeds & speeds, …)
…and your belts are too loose…
