Problem with X axis movement
I have had a similar experience, where after nudging it a few times, it appears to have initialized and is currently working. I have not contacted support yet, as this is my busy season, and as the old saying goes, if it ain’t broke (right now) don\t fix it! I will revisit this once I’m either past the silly season, or it rears its ugly head again!
Problem happening again today. Just ruined over $200 worth of product with X-axis jamming again. This machine has not worked right since day one, and definitely NOT happy right now…
Saw your ticket in our queue, and added a link to this discussion for folks to refer to when working with you.
I’m a little late to this thread but I had the same issue. I solved it by retracing the cnc build and rechecking everything making sure everything was square, level. and tightened. Pulled the x-axis motor (p.24 of install manual) and re-seated the motor into the coupler. Issue went away and it’s been running perfect.
I hope this helps anyone else with this issue.
Cheers,
