Hi All, so i tried to cut a file that i had used a few weeks back and now when i run it cuts in the air.
nothing changed. Here are the files.
big s.c2d (14.5 KB)
big s.nc (248.2 KB)
Thank you,
Rob
Hi @Lgthousefab,
That G-code has the Z zero set at stock bottom,
Did you maybe zero on top of the stock by mistake this time around ?
Hi Julien, Yes I did. I feel stupid.
Thank you
There is nothing to feel stupid about. These type of lessons are not forgotten and the next time you cut air you will remember to check for top or bottom. No harm no foul you only cut air and learned a valuable lesson.
