Problems using Universal G-code Sender
I’m a relatively new Shapeoko user and wanted to try using Universal G-code Sender instead of Carbide Motion. Every time I try running a job with UGS I get a limit error code similar to:
[Error] An error was detected while sending ‘S5000M3’: (ALARM:1) Hard limit has been triggered. Machine position is likely lost due to sudden halt. Re-homing is highly recommended. Streaming has been paused.
[MSG:Reset to continue]
The g-code was generated from Fusion 360 and runs fine in Carbide Motion. I did remove the tool command from the g-code before trying it in UGS.
Any ideas?
