If I router a project and see that I did not set the depths deep enough, can I go over it again after changing the depths?
Yes, that is relatively simple. For things like pockets, you can even set the start depth to be how far it already cut, so you don’t waste a bunch of time cutting air.
For VCarves in particular, you should not limit the depth in the first place - let it cut as deep as it needs to. If you do want a “limited depth VCarve”, use an Advanced VCarve instead.
The most important thing is making sure your project zeros are the same relative to the stock, and the the stock is aligned the same way. If your stock is still on the machine, you’re good to go.
Excellent. Thank you very much
