Hi all, haven’t used the machine (Pro) in a while and when I powered up today, the proximity light, the one next to the router, would not go off. The other 2 are off except when I put a wrench near them, but this one just has a constant light.
If your Z axis is all the way up, the light will be on, that is normal.
If you jog the Z axis down the light should go off. If not, then there is a problem.
