I have a Shapeoko 5 Pro 4x2 and I have a spindle which works great. I just started 3d carving and I made a wood spoon. I did two cuts side by side the top and back as you can see in my photos here. I used a 1/8" bit but I have some questions. I am wondering how a 1/4" bit would work on the rough pass and then a 1/8" bit on the finish pass and what would be the recommended step over?
This is just my first test cut and now I have a Jig that I made which I am excited to give it a try this weekend. When I use the 1/8" bit the bottom cut, takes over an hour and I can cut that down by 1/2 the time or less if I use a 1/4" but I wanted to get some opinions here if that will actually work well?
I am assuming a ballnose bit would be the recommended tools to use?
