Question about Vcarve bits
I do a lot of projects with the v carve toolpaths in cc and i was wondering if it is possible to program in a 120 degree v bit for projects with wider spaces to save time by skipping the pocket toolpaths while still keeping the bit from going too deep?
Yes, if you also use that angle tool.
Which angle tool are you speaking of?
You would need to use a 120 degree V tool, as specified.
