Using CC644:
Edit the text so that it’s a single letter:
Horizontally align it w/ the circles:
Select a circle and use the Move command to determine the location of its center:
Use Circular Array:
applying the center dimensions.
Change it to an arc:
Adjust the parameters until things line up as desired and one has the desired number of items:
Duplicate and align one of the circles w/ the original so that it can be enlarged so as to be larger than everything:
Select everything and rotate to finish the positioning:
Duplicate each letter and align the duplicate w/ the original:
edit the duplicate letter:
drag it into position relative to the original:
Delete the original:
Repeat for the other letters:
Select the letters and the outer circle and rotate as necessary:
Attached.
Margie.c2d (752.6 KB)
