Nomad arrived today and I was up and running in literally 15 minutes. Downloaded Meshcam and Carbide Motion on my computer, connected it to the nomad, and she started right up
First up was the wrench. Went off without a hitch and turned out beautifully
Second, I loaded up the reshape, opened the 3d face file in Meshcam and generated a toolapth, saved the file and loaded it into Carbide Motion. I did the cut twice - here are the results
You can see that on the first try, the cut wasnât done properly on the left side of the face. I figured maybe this was because I loaded the reshape in horizontally rather than vertically, so I tried again
This time, the cut wasnât done properly on the bottom of the chin. I could actually see that the tool was going through the motions to cut, but it was not on the material - it was moving around a little below the chin.
Any idea what may have happened with these 3d cuts that caused this?
PS I also had small horizontal ridges or fins during the roughing pass, so perhaps I also have some movement in the y axis belt like others did? I checked and it appears to be tight.
Right after I posted and looked at the screenshots, I noticed that itâs the waterline cut that was the problem. The 2nd time I ran the cut, with the issue on the chin, the left side of the face has a problem too - but only where the waterline cut was. Where the parallel cut went through, it looks just fine.
Youâve posted the toolpathsâwhich as youâve discovered are helpful for diagnostics too, but I was looking for the settings dialog in MeshCAM itself
It should look something like this, but Iâm looking to see what the different values in yours are.
Iâm not exactly sure how to get to the screen youâre showing after choosing a Carbide Auto Toolpath from the menu settings. It does the calcs, shows the box where I can click around on the cuts etc. but there is no way for me to get to the screen youâre showing. If I start from scratch, then of course I can get to the screen youâre showing.
So perhaps Rob or someone - when I run a Carbide auto toolpath in Meshcam, how do I get to the screen above so I can look at the settings that were automatically generated?
To get to the window shown, make sure you check the box at the bottom of the auto-wizard for âReview Toolpath Settingsâ and youâll be good to go:
Thatâll give you a chance to see what it suggests, and then adjust it from there.
