Hello. I’ve been using my Shapeoko 3 XXL for a while now, and am just coming across this issue. While the machine is running, as it’s going to do the next stepdown, it plunges way too far. There doesn’t seem to be any consistency with how long the machine is running before this error, however, it only seems to occur once every time I turn on/power cycle the machine. After this errant plunge occurs, if I simply restart the g-code, it works just fine. I’ve machined for several hours, running several different programs after the random plunge both times it occurred and there were no further problems.
This happened both times during a facing operation generated by Fusion 360 with the “Carbide 3D (Grbl) / carbide3d” post-processor with the default settings. After the plunge, I felt the temperature of the spindle and all of the stepper motors, all of which were cool to the touch. I’ve seen other posts suggesting that errant z-plunges might be caused by an overheating stepper driver/control board, but given that the machine flawlessly ran the same g-code to completion immediately after the error I don’t believe that to be the case. Does anyone know what could be causing the problem? Thanks in advance!
Image of the result of the plunge below:
