Does Carbide create pro have Raster?
It’s the facinging operation.
NOTE: the face operation is designed to cut an open face, with no walls, i.e. the top face.
It won’t honor the boundary along the direction of cut. It will stepover on the end boundary.
The Engrave path will do a pass around the boundary, ON the boundary. But it also does a zig-zag with lifts pattern. The stepovers will be retracted, so it will plunge/retract on every pass.
To do a true zig-zag (raster) path with the stepovers where you want them and inside the boundary, you need to draw the whole path & use a contour toolpath.
As noted, if one considers the Facing operation to be that, yes.
One can do this sort of thing manually (sort of) as described at:
