Relative scale on multi-selection in CC?
I was making a threaded wasteboard, but had to stop the project part way through as I had to run out of the shop. After my return, I kicked on the machine and re-ran the project, figuring all my settings would be still in place. Problem is, the recess for the threaded nut didn’t come out perfectly centered on the 2nd run. The original ran holes are perfectly fine (about 20% of the total project), the 2nd run holes cause the insert to sit proud of the bottom. So, to fix it, i’m just going to run another pass on the recess, with a 10% increase in size, to allow for whatever error snuck in.
So, my question is, how do I multi-select the recess’ and scale them relative to their center points, not as a grouped center in CC? Really hoping I don’t have to individually select and scale each of the 200 recess circles.
