Has anyone used a torch type of lighter to remove fuzzies.
Did you rerun your finish pass ? It may clean up better.
I have used old tooth brushes, brass brushes of varying stiffness, floor brushes before my sanding. It all depends on your wood or plastic. As previously mentioned, rerunning the finishing pass at .001 added depth might help. Works on harder wood, on softer woods it may make it worst.
Good luck
Per @Zman suggestions, if you are cutting softwood, a coating of thinned out shellac will stiffen the fuzzies and may cut better. Let it dry for a day.
