Repetitive parts library
What ive read is old, has it ever been addressed in having a repetitive parts personal library?
TIA
Since you can import one C2D file into another, could you use that as your parts library? Once file per part, then you can import them into any other project as needed. You can even have toolpaths set, and those will import as well.
You can also store .svg files in the user library C:\Users<user>\AppData\Local\Carbide 3D\Carbide Create\library. folders will become groups in the library, and files can be added to your parts.
Will these be deleted and replaced when updates are applied? Currently I do what @mhotchin suggested but it would be nice to see them in your personal library.
It does not appear so, My library of images has followed me from CC version 778 to 813.
