I’m replacing the logic board on my 3XXL. I used a heat gun to heat up the black case so I could pull off the board off. The aluminum heat sink is still attached to the old logic board. Is the adhesive between the aluminum and the logic board also heat sensitive or do I need to just carefully pull the aluminum off the old board? I don’t want to use a heat gun directly on the back of the logic board if I don’t have to.
Please check in w/ support@carbide3d.com for the specifics on this.
Just for the record: I emailed them and got a phone call back within 20 minutes. (Probably within 10 minutes - didn’t check for sure.) Problem solved. Thank you!
