Reset Feed Rate in Carbide Motion when a tool change occurs
Please reset Feed Rate override to 100% in Carbide Motion when a tool change occurs. Currently, what ever Feed Rate is set (+ or -) carries over after a tool change to the new tool. Oftentimes, I bump up the the Feed Rate as one tool path is getting close to finishing because the depth of the final pass is shallow. Then, I forget to reset the Feed Rate after I change the tool.
This would be tricky. The benefit of manual override is that the user makes the choice. With your method, it would the software determining when that manual override is no longer needed.
This is something we dealt with years ago. We used to reset the feedrate overrides more aggressively than we do now, which led to many support emails from people who didn’t want it reset without their permission.
I don’t know if we arrived at the “right” or “wrong” solution with our current code, but it seems to be the “minimum complaint” solution.
This is not meant to brush off the request, but to give a little context on how we got to where we are. I promise it wasn’t random.
At point the only opportunity to reset the speed is if you start cutting a new path.
A button to reset it would work.
Can be done is a macro ?
@DaveS
I personally do not want an automatic reset. Each different wood grain type will allow different feed rates based on the specific tool path/cutter. When starting my tool paths I will adjust as needed for the project which carries thru the remaining tool paths. It would be a pain to have to manually adjust the feed rates for each remaining tool path for one project.
This is my preference, everyone has their own.
An elegant solution would be a checkbox next to the feed override buttons that says Reset on next tool change…or something to that effect. Normally unchecked…you would deliberately check it when you’re doing the override.
Would solve both worlds, no?
What if my material dictates a 25% feedrate. I surely don’t want it resetting to 100% between tools.
I’ve almost made this same request before, but I didn’t because I’d also want it to be quickly toggle-able.
Sometimes I have a species or cut of wood I’m cutting for the first time and I want to reduce speed on every toolpath
Sometimes I’m running 3 separate boards of different woods side by side with array toolpaths. If I manually adjusted feed for board A, I would prefer it reset when the toolpath repeats for board B.
Sometimes I’m just testing a new toolpath and want to run it slower in between two other programs I’ve used repeatedly. There I’d also want it to reset.
I’d even take a way to do this in gcode via post processor (vectric user). In my limited GRBL understanding I imagine its not possible. The CM log doesn’t capture any input when the increase and decrease are pressed.
With all of these type requests, I do appreciate hearing from the Carbide3D team about what’s normal across the CNC space.
I may be in the minority here but I prefer to not have too many things reset automatically without my thought/input. I can see this tripping me up at some point.
A lot of times I’ll run a roughing pass 60 to 80% faster than default for the bit. When the bit change comes around and I load a .5R or .25R MM tapered ball nose that faster feedrate could take it out. Personally I would rather start running that second bit at the speeds I defined it at, then adjust as needed during the cut. I think @GJM suggestion, if doable, is a good idea.
Sounds like I need to make sure I double check the feed rate when I change a tool. Thanks for your thoughts folks!
Is this a quick action macro to reset to 100% feed ?
