Really? Does that work for mdf? I was going to leave it “as is”, with the other ‘spurious’ cut that happened when I exported the gcode directly from CC into CM, and that went wrong!
I have the same DeLongi heater, but the version with knobs and the rotary timer. As you say, it’s excellent for a workshop.
I also have the same bench… yesterday I put a shelf in the bit with the sliding doors which made that area much more useful (for me).
I didn’t dismantle the bench. I used a piece of offcut plywood as the shelf, roughly 70% of the depth of the cabinet, and screw/glued 20mm strips of pine around 3 of the edges of the shelf. Then I slid that through the doors and held it aloft with a couple of even bits of wood, then screwed the three bits of 20mm pine to the MDF front, back and sides… making sure that on the drawer side, the screw had no way of going all the way through.
Not the best job, but not totally Gerry-built either
edit: a photo to indicate of the lack of effort I applied in this modification:
Sorry about the wasteboard indecent Peter!
Hopefully @WillAdams or @fenrus will have a moment to look at this for you as both are super at the details explanation. You might also have another look at Will’s link to double check.
I’m not well versed, though I’ve paused as described and successfully continued previously.
And yes, the glue and sawdust trick does work to repair a cut in the wasteboard, guess how I know
Not sure that’s been answered yet.
Are you calling my wasteboard indecent, Mike?
I’ve actually just completed the job now - not fixed the scar yet - but had to do it in fits and starts, because what was zero in one run, wasn’t the same zero (although it was close) in the next run, so I exported fresh G-Code files after removing the cuts already made to reduce time and not oversize any cuts already done.
I did try to do the trick with editing the original G-Code file, but must have made a mistake because that’s how I ended up with the scar in the first place. If nothing else, I will need to look at that in more detail, in case I need to edit the G-Code in future! I’ve bookmarked the link ![]()
I thought the dust and glue story was a bit like going to the workshop storeman and asking for a left-handed hammer or a long weight. My apprenticeship was such fun!
I suppose it’s just a case of mixing a lot of sadust with a bit of woodglue?
One definite I’ve learned to day (I already knew this, but these last couple of days has confirmed it - I really don’t like cutting MDF!
Thanks, Mike ![]()
D’OH! Sometimes knowing too much about someone else’s wasteboard shouldn’t be public!
