Restarting a Tiling Job and why the issue
I am new to CNC and have a tiling setup problem. I was cutting a simple door cutout and on the 2nd tile cut after moving the board it started cutting before it should have. I hit stop to prevent it messing up the whole board and moved the board to try and accommodate the messup, but now I have to restart a new job. How do I get it to start on the 2nd tile rather than the 1st tile?
Not sure if you have seen this video, I had to watch it a couple of times to understand how it works.
Hope this helps.
:grinning:
You loaded the file for the second tile? There are different files for each one. You need to make sure it is saved that way and load the correct one for each piece.
